rc1626
- January 31, 2002
- Long Island, N.Y.
- 99 Explorer XLT
Hey folks,
I have a 99 Explorer 5.0 AWD with 152k on it. Last March it started with an idle stumble. Noticed it while sitting at a light. Previous to this the only thing that was done was new Champion plugs a Seafoam treatment through the PCV line and a new PCV valve. After the stumble I threw a couple of bucks at it with new coils and wires. I've cleaned my MAF, tried a new IAC and TPS with no luck. I've gotten maybe 2-3 misfire codes since this all started in March. The truck runs well otherwise. Runs strong with no known change in fuel economy. I do feel some pulses when cruising at low speeds ie.up to about 30mph. I also pulled the cam sensor cap and did not see any damage, dirt, etc.
The other night I pulled all the plugs and did notice a tiny amount of hard crusty carbon deposits on the electrodes which I cleaned and reinstalled with no change in performance. As for vacuum leaks I don't hear or see anything.
I plan on testing the compression numbers as well as vacuum numbers. I'd also like to replace the plugs again as I feel the Seafoam treatment may have been the cause for the plugs looking the way they were. I'm also thinking I might pull the plenum to get a look at all the vacuum lines and check for any issues. I have a scan tool but have limited knowledge as to what the numbers mean for o2 banks and fuel trims etc. I don't particularly want to be throwing money at the vehicle and thought I'd post here looking for some direction.
Any help would be appreciated.
Thanks.
Thanks.
