Here is a tsb that might fit your concern.
Printable View (7 KB)
TSB
05-20-11 VIBRATION/MOAN DRIVING 75-80 MPH (121-129 KM/H) - 4X4 WITH 4.10 AXLE
Publication Date: October 3, 2005
FORD: 2001-2005 Explorer Sport Trac
ISSUE:
Some 2001-2005 Explorer Sport Trac 4x4 vehicles equipped with a 4.10 axle ratio may exhibit a vibration/moan condition while driving 75-80 MPH (121-129 Km/h). This may be due to a driveline imbalance condition.
ACTION:
Install a new aluminum rear driveshaft with eight (8) new attaching bolts. Refer to Workshop Manual Section 205-01 for Removal And Installation Procedure.
NOTE: IF THE VIBRATION SPEED RANGE IS BELOW 75 MPH (121 KM/H) PERFORM NORMAL DIAGNOSTICS AND DO NOT PERFORM THIS TSB.
PART NUMBER PART NAME
3L2Z-4602-AB Rear Driveshaft Assembly
N800594-S100 Bolt Kit (4 bolts per pack - 2 packs per repair)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
052011A 2001-2005 Explorer Sport Trac: Install New Aluminum Driveshaft (Do Not Use With 4602A) 0.7 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
4602 D9
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2005 Ford Motor Company
