zerodevil
- March 24, 2008
- Anchorage, AK
- 2008 White Limited V8
Hey Yall.
I have a 2008 LTD with the 4.6L 3v. Recently discovered I have a slow coolant leak somewhere, that I have thusfar not been able to locate. there is no obvious puddling, or wet spots inside of the engine bay. There is no Coolant in the Oil, and no oil in the coolant, so fairly safe to rule out head gasket issues. My larger issue is that I have a completely random misfire/weak fire. Its not enough for the truck to turn on the CEL and give me a code. Truck will be 100% fine for 20-30 minutes, and then start sputtering/missing/lurching for awhile. Also appears to not care if the truck is warm or cold. Did Coils and Plugs a little over a year and a half ago, all motorcraft, all done per the manual. I'll pull the coils and check them with my meter tomorrow at some point.
In the meantime I was wondering if these 3v engines are known to have intake manifold gasket issues? Any other known trouble areas to look at?
