BP99Sport
- December 27, 2000
- Coral Springs, FL
- '99 Sport
I went out this morning to go to work and couldn't get my truck in gear. I checked the master cylinder fluid level and it was empty. I filled the resevoir and tried to bleed the system. Chiltons says gravity will do the trick. Nope. I had a friend depress the clutch pedal and this NASTY gunk came out of the bleeder valve. It was thick like molasses and white.(???) For the next few iterations of the bleed procedure, DIRTY hydraulic fluid did come out, but it was slow. Then it just stopped altogether. The fluid level never dropped thru the whole process. There's obviously an obstruction of some sort in the system. I will be buying a vacuum bleeder tomorrow and try to clear the line.
My questions are.....
Anybody ever seen anything like this before?
Is this a symptom of a bad slave cylinder?
Any input is appreciated.
Thx
BP99Sport
99 Sport 5-Spd 4.0 OHV 96K miles
Thx
BP99Sport
