Something seriously wrong | Ford Explorer Forums
venom204
I posted this awhile back "When i attach the seatbelt when driving the seatbelt light and noise comes on, light flashes and dings, and then goes off then back on again for like 20mins. Anyone have an idea of what might be causing this? Kinda weird the horn and cruise control stoped working after this started and i checked fuses and the horn was blown, replaced that and now the horn works but its still doing it and the cruise no longer works" Now without anything figured out while i was trying to use 4 wheel drive, when flipping the switch no 4 wheel drive no lights no nothing it seems to be dead as hell anyone have any idea?
bad ground!! whenever you have this many weird wiring issues you should first look for a grounding issue.
main grounds near batt on core support, 1 behindkick panel driver side, 1 under center ashtray or if you have full console under the front of that, there are alot more but look at these first
