RammaR
- August 21, 2001
- Franklin, TN
- '96 XLT 4x4
I've got a '96 XLT with the "premium" factory cassette and CD changer (no sub that I can find), and the front passanger side speaker starts to cut out intermittently. It doesn't cut out completely - because when you adjust the fade and balance you still hear sound, just very very quiet compared to the other 3. It normally cuts out after hitting a bump or sometimes closing the doors. Also, sometimes just that 1 speaker sounds blown... scratchy, like the wire is just making contact. Anyway, today I pulled off the door panel to check on things and here's what happened:
I pulled the speaker out and wiggled the wires and shook the whole speaker and it played perfect. Then I put the speaker back in the door with 1 screw and closed the door hard.... it went nearly silent. I opened the door and pulled out the speaker again and used a mutimeter to measure 4-ohms across the leads still. To get the speaker to play normal again it normally takes another bump or door slam... but i learned something new... if I quickly turned the volume up and down a few times it came back to life! Now i'm afraid it might be the head unit. I pulled it out and wiggled the wires behind it with no luck. It never cuts out completely as if the connection was totally broken. I'm tempted to pull off the other door panel and swap sides to see if the problem moves, but am now thinking it may be in the HU.
Has anyone had anything similar happen? Any advice on what to check or try next? My multi-meter is pretty cheap, but is there a way to measure the line voltage to see if its dropping off when it goes low? I tried using dc volts and didn't get anything with it playing good or when screwed up.
I was thinking of using the "speaker" problem I thought it was as an excuse to upgrade to better speakers, but now I don't want to do that if I have a HU problem.
Thanks for any help!
