speaker problem | Ford Explorer Forums
speaker problem
Eskimo Joe
Columbus, Ohio
'96 XLT
My front left speaker keeps cutting in/out. If I crank up the volume, it sometimes comes back on. But as soon as I hit a bump, it goes back out. What can be causing this?
Probably a loose or partially cut wire. Also, are they the stock ones or aftermarket?
yea im thinking the wire is either cut or coming loose. check the plugs and see if they are attached right, and if the wires are loose or not.
just take off your door panel and see if its still pluged in. i had my front right speaker out. turns out when i opend my door the wire had some how snagged and pulled off the speaker. i kinda pulled it out a little and plugged it back in.
