Speedometer Problem Bouncing Buzzing | Ford Explorer Forums
crivas13
Dallas, Texas
'94 Limited
Hi,
My speedometer jumps about 10 MPH and kind of buzzes when i hit around 65 sometimes by itself or when i hit a bump. I could sometimes hit the top of the dash and it would stop momentarily. I took it to the dealership and they said it was a bad speedo head, but i dont think they did any extensive checking, said it would be $800 to fix. I took the dash off this weekend and disconnected it, shot a little white lithium grease on both ends and now it jumps around at 45 or more and buzzes. When i pushed the cable back in i pushed intil it clicked. Should i buy a new cluster on eBay or is it maybe the cable. I see that they have the new cable at autozone for 3.95. Is the cable hard to change? Any suggestions?
Thanks,
Carlos
Try a search for speedometer bouncing. I know there have been a few threads about it. From memory, I think it has to do with maybe the cable being loose at the back of the speedo, but I am unsure about that. But I know a search will benefit you.
Robb
did you grease the entire cable by disconnecting it at both ends and pulling it out? is there anything different about/around the cable housing that might be causing it to bind? when you pulled the end out of the speedo were the ends still crisp or were they slightly worn? it wont be your cluster, it'll be something to do with your cable. if you buy a new cable make sure that the new one comes with the square rubberized tips and not the wound cable as the end.
No, i didnt pull the whole cable out, wasnt really sure how to do that. I checked out the search and they seem to suggest that if it buzzes its the speedo head and if it was the cable gone bad, it would bounce at all speeds. I think im gonna get a speedo head on ebay and see if that fixes it if not try the cable. Is the cable easy to replace?
Carlos
