Starter and flywheel gear inadequate mesh | Ford Explorer Forums
jr7588
Fairbanks, ak
1994 Explorer 2D
4.0 sohc with the manual transmission
The truck has had a questionably done clutch replacement at some point.
The starter that was on it when I got it only engaged about 0.08" of the flats on the ring gear. I replaced it with the model Napa recommended when I discovered it was unreliable. This model had the same problem. I tried an auto zone model and same thing. All the starters still work and all the bendix gears slide a similar distance. Geometries regarding gear size, # of teeth, and depths from the mounting bosses seem the same. Is there more than one starter/flywheel combination for the 4.0 sohc manual? Is there an operable but incompatible flywheel that could be installed?
No crank endplay and the clutch works quite well.
If you have a 94, it has the 4.0 ohv, not sohc. The sohc is Gen2 and up.
There’s a difference between starters for auto trans and manual trans, maybe parts stores are giving you auto starters?
