Steering pulls to right?? | Ford Explorer Forums
P51DTUG
Tulsa, Oklahoma
1992 4x4 Sport
After adding 31x10.50, coil spacer/AAL and getting an alignment, my truck pulls to the right. Tires have been rotated every way possible to see if it's a tire problem. I took it back to the alignment shop 3 times and they tell me that the align. is perfect and the frame must be bent. Radius arm bushings were also replaced w/ coil spacers. AAL went in with no problem. Crazy thing still pulls to the right. I'm planning on going to a different alignment shop Sat. morning.
Any input/ideas on what is happening?
Thanks..Jim
Go back to the alignment shop and tell them you need more caster on the right side or less on the left, or a little of both. An alignment shop should know that but sometimes they're retarded.
