Steering Stablilizer!! | Ford Explorer Forums
Adam Foote
Katy, Texas
92 XLT
Hey guys, could i put a steering stabilizer or even a dual steering stablizer on my 92 ttb ? if yes how hard is it? thanks ahead of time
Yes you can, its not hard, I don't think a dual will fit...
I have a Rancho for a Ranger from summit and it required 3 holes drilled on the crossmember. I think the Hecklethorn ones from JC Whitney require no drilling and are only like $40. When I installed mine I noticed a huge difference in control and bump steer....good difference. Hope this helps.
so you think i will be able to install a hecklethorn myself?
yes a dual will fit... i have dual skyjacker on mine. i did it myself and i have pics if you would like to see
how much does the skyjacker cost? i want to put one on mine too... (only one, not dual)
Thanks everyone, Yes 94eb i would like pics, i had my friends at maximum offroad order me one, either explorer pro comp or rancho i believe, he said he would find out which was better, thanks again
Dead Link Removed Dead Link Removed
i thought i had a pic of them closer but in these old pics i have you can see the dual under there.... not hard to install drill to holes in frame youll just have to find where it will work and angle it so it clears.
SWEET X
Nice rig. Will they work on an x with out so much lift?Where about on frame did you have to drill?
Thanks, David
I've got another question, where did you get your flares? They look good, sorry about posting twice, did not notice flares till after I posted earlier.:bounce:
the flares are bushwackers.... and i drilled right behind the clip for the abs cable on the passengers side frame rail..... with the bracket angeled to the front .... and i dont see why they wouldnt work on an X with little or no lift.
cool
Yhanks for the response, I want to lift mine, but that's not for awhile, but I do want the staybalizer now.
Thanks
looks good, you think you could post some pics of my truck on this thread after i get it, im not elite,,, YET...
thanks
94EBexplorer
One more question on your staybalizer, Did you order that for an explorer, or for another vehicle?
Thanks David:D
i orderd it for explorer Skyjacker lists a dual for the X
94 EBexplorer
Thanks for the response, I replaced all my front bushing now I'd like to put a staybalizer on it.
I GET MINE TOMMOROW!!!!!!!!!
just be careful when you install it ( if you have superlift front sway bar drop brackets ) that you have enough space to clear them or youll get major problems.
