strange readings on fuel gauge | Ford Explorer Forums
sajnaj
rockville in
91 xlt
hardly any guages
i checked my restincae at the tanl and it was about 100 and at the gauge i got 200 ohms is there somthing wrong with that and also the only gauge that works is the spedomter
The normal resistance for the sender is 15 ohms empty and 170 ohms full. You could check for sender voltage at the tank connector, but doubt you will find it. Could be as simple as fuse to gauge cluster.
checked all them al ready and it think it somehting with the gauges i took out anp layed with it had free movemnt so i dont know most of my guages dont work
is there a specil fuse that opreates the gauges taht is not in the fuse block
