terryjoe
- August 14, 2009
- 94 xlt
i recently obtained a 94 with electronic 4-wheel drive that was stuck in 4-low. After checking all the fuses and what not i could not find the problem. I removed the electic motor from the transfer case and shifted it to 2-high manually and then had to run a jumper wire from the battery to re-align the gears to re-install the motor. Does anyone know where the hidden relay or whatever device that controls the shift motor may be found?
