stumbling then suddenly not stumbling | Ford Explorer Forums
jamie3529gq
Lapeer, Michigan
2001 Mercury Mountaineer
My 01 5.0L mountaineer was doing some weird stuff yesterday. Left work, it started and ran fine, about 5min in it started stumbling badly, so bad at times I didn't think i'd be able to keep going. then suddenly it would stop stumbling and the truck would take off like a shot. like flipping a light switch. did this off and on all the way up I75 for 20 miles, had to watch i didn't run into the back of someone when it suddenly stopped stumbling and surged forward. then, the problem stopped for 25 miles up M24, ran like a top. Stopped for smokes at a gas station, truck would hardly run again. pulled out and floored it, suddenly HOLY CRAP here it goes - took off again.
Ran codes when I got home. O2 sensor heater failure, fuel trim on bank 2 ( i think - gotta check again) was way negative, -25%, misfire detected cylinder 5, etc etc . I was like armageddon on the code reader.
I just don't understand what would make the issue turn on and off like a lightswitch on my way home. I am thinking a bad wire somewhere? Any thoughts before I start replacing stuff?
Thanks!
Also last weekend I replaced my rear bumper,it was bent down badly from a rear ender. I had to beat on the frame rails pretty hard to straighten them. I don't imagine any connection to this problem, but who knows??
more info. codes P0155, P1151, P1152 and P0305
started it up this morning, it looks like bank 2 sensor 1 is stuck at around .465V, doesn't vary more than .01-.02 volts. bank 1 sensor 1 runs from 0.1 to .75 volts.
Short term fuel trim bank 2 sensor 1 was sticking around -23 to -25%. Truck was chugging nicely at idle, engine vibrating quite a bit, you could spill your coffee.
It all points to bank 2 sensor 1 oxy sensor, but i don't understand the 'on/off' characteristic of the problem yesterday.
Hope it isn't an open injector like mine. The intake has to come off. I have the same systems and I know it is injector 4. A bad wire that sometimes gets good connection could be both our problems. Either way intake has to come off.
i replaced the driver's side O2 sensor, prior to the cat, seems to have fixed the issue. Motor is smooth as butter again, and the fuel trim bank 2 is back around zero. Only drove about 5 miles though, idled a long time, no check engine light, no stumbling. Here's hoping....
Still don't understand the intermittent deal, but whatever, it seems fixed.
Update on this one. Truck sat for 2-3 months (mama wouldn't let me have insurance on my Ranger and my Mountaineer at the same time) but I recently re-insured it to get it ready to pull my 4 wheeler on a trailer up north. (next week, can't wait)
First off, the first day I drove it again (after changing all the rear diff bearings) the alternator failed, I almost made it back home.... anyway, that's a side story.
After fixing the alternator issue, the next day it did some random 'stumbles' again, short duration, motor shakes like an SOB. Then like a light switch, smooth again. No error codes, but I had the code reader on my phone while driving to work the following day so I could watch the fuel trim if it happened again. Only 10 seconds it happened, but I caught bank 2 fuel trim drop way negative while it was stumbling.
I remembered when I changed the O2 sensor that there was a lot of oil around the connector, so I got under the truck, disconnected the sensor and sprayed the whole thing out with brake clean. Put a bunch of dielectric grease on the pins, and reconnected the sensor. I swear the truck is now running and idling smoother than it has in the two years I've owned it.
Probably should fix that oil leak someday...
