stupid question about lifts | Ford Explorer Forums
Union NJ
2000 explorer eddie baur
hey this may seem stupid, but i had a brain fart... well im ordering the p883 lift kit and the warr shackles, and going to to the TT(torsion twist), WOULD I NEED TO GET LARGER OR LONGER SHOCKS???
thanks
steve
stock length will be fine as the front control arms have the same amount of travel tt twisted or stock, reason being is that you are essentially giving up some down travel (droop) for more uptravel(twisted) ride quality isnt changed that much though.
the rear you should be fine as well as most stock shocks are not the limiting point of travel, the spring usually is, with that said the stock shock should have enough travel in it for the extra 1" or so of lift
u will be fine
