Sway links torque specs | Ford Explorer Forums
Lunchbox111
Midwest City, Oklahoma
2006 Explorer Eddie Bauer
I own a 2006 Explorer Eddie Bauer. When driving if I hit bumps I hear what sounded almost like chains swinging around under the vehicle. Got underneath and took a look and there were no longer any bushings on the front sway links and the bolts were just sliding up and down and bouncing around where they go. Luckily, they were beyond easy to remove. However, when I put the new ones on I couldn’t find any torque specs. I followed the directions that came with them stating tighten until you can see the start to bulge then loosen 1/4 turn. If anyone knows the proper torque or where to find it I’d greatly appreciate it
Are you replacing them with the OEM type or aftermarket end links? OEM torque spec is 18-21 foot pounds but are hard bushings. Aftermarket often use softer thermoplastic rubber bushings or similar and don't usually mention specific torque specs. Instructions usually say after the bushings slightly bulge tighten 1/4" turn more.
Found in "Similar Threads" on bottom of this page:
Sway bar bent? Stabilizer / sway bar links worn
These are the aftermarket with the thermoplastic bushings
Moog technical service said that they use the same recommendation for either version (blue thermoplastic, or white polyurethane):
1. Tighten until you can no longer turn the center sleeve by hand.
2. Continue tightening for 2 more full revolutions.
I intend to use this procedure, but I will use a torque wrench to monitor torque. Once I'm into step #2 , it sounds like I don't want to get anywhere near 26 ft-lbs, even if I haven't reached 2 revolutions.
^ Post #20 from linked thread above.
