TA/SVO axle girdle....w/sway bar? | Ford Explorer Forums
Anime
EF YEAH!!
2018 EX Sport Concept
Ok I did a search and came up with diddly so I have to ask before I spend money and learn the hard way.
I need to know if the T/A / SVO rear axle girdle for the 8.8 clears the stock sway bar when it swings?
I know I have to cut the spare tire mount under there so it wont scrape it, but I'm curious if the sharp corners of the girdle mess with the sway bar itself...particularly when flexing big time ..since the bar twists and goes up and down right behind the pumpkin with such movement.
Of course, theres always the possibility I'm the only person who wants the girdle and the sway bar together..:confused:
You will have to disconnect the Sway bar for the Install but I had the SVO cover on with the Sway bar till I got my lift almost two Years and Never had a problem.
Sweet!!!
Thanks guys! :chug:
