Tyler Robinson
- August 4, 2017
- Ohio
- 01 Sport 4x4 2dr
The thermostat is good, I have heat. Iv replaced both the temperature sender & temp sensor, could I have a bad ground somewhere? Because some days it’ll sit right past cold , but usually it sits under cold. I have a 4.0 v6 sohc if that helps. Iv searched around the threads on here but can’t figure out what the problem is
