Nibroc99
- August 21, 2020
- Rochester, MA
- '13 PIU Base
Footage of the humming noise:
Please... Somebody, anybody, I need help. 2013 FPIU 3.7. This noise will not go away and it happens on the highway ONLY when it rains and I go over 60 mph. It's so strange. And it's overwhelmingly loud, can't hear people talk over it.
Has happened since I got the car, so it isn't any of the stuff I've added like the brush guard or lights on the front or anything. I don't have any light bar on top either so it's not that.
Noise is a constant pitch - no change in pitch based on engine or vehicle speed. This leads me to think that maybe it's a "whistling" effect from something, like it is getting wet and then that causes it to "whistle" that loud tone.
Tried putting it in neutral when the noise happens, and there is no change whatsoever. So that rules out transmission noise I guess. Idk, someone mentioned trying that when I was at the shop haha.
Replaced tires and it still makes the same noise.
My mechanic says that all of the wheel bearings seem to be fine. He could not for the life of him figure out what could be causing the noise.
PTU fluid has been changed and looks healthy, along with rear diff fluid, tranny fluid, and regular oil changes, so it's not that either.
There are no belly pans or air dams or anything that could be causing the issue.
CV axles appear to be healthy, no rust or signs of play in the U joints or anything.
Driveshaft has no play in it and U joints look fine on it as well. Very little rust on this car which is awesome. Center bearing has no play.
Noise comes and goes a bit, but this video shows a best-case scenario... Normally it doesn't just fade in and out right away. Normally it'll be like that for minutes on end.
Does anybody have any idea what could be causing this noise?
