natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
I'm finishing up putting the top of my engine back together (lower intake coolant leak & replaced rockers & pushrods) and whipped out the new thermostat I bought. It's a Stant SuperStat 45369 195*. Compared it to the one that was installed and noticed that there was no air bleed hole on my new one. Is this a problem? I've already got the new one installed but will finish assembling everything tomorrow to fire it up.
*EDIT*
The one I ordered is a "premium" one from Rock Auto. According to Stant's website, it's ok?
*EDIT*
WHAT DOES A JIGGLE PIN DO?
It helps bleed the cooling system of trapped air by allowing air to pass into the radiator and released from the system.
MY THERMOSTAT HAS A JIGGLE PIN BUT THE STANT THERMOSTAT DOESN'T. WILL A STANT THERMOSTAT STILL WORK?
Yes. Many thermostats have a “jiggle pin” that allows trapped air in the cooling system to pass through the thermostat and be released from the system. Some Stant thermostat do not use have a jiggle pin. These thermostats will have a "bleed notch” or other method of removing air from the system.
