iajet
- November 21, 2010
- Torrance, CA
- '99 EB 4x4 & '10 XLT 4x4
My 99 Explorer EB was leaking a small amount of engine coolant so I took it into the shop the other day. Prior to the work performed the temp gauge just barely touched the bottom round portion of the thermometer on the gauge ( roughly halfway between full cold and full hot) and the gauge, once the engine was off and cooled would indicate full cold.
After the water pump, serpentine belt, t stat (stant 13648 180 degree t stat) and t stat housing o ring was replaced the temp gauge never indicates about a 1/4 up the arc, so about half what it indicated before and when the engine is off and cooled stays in that same position. However when I start the truck the gauge goes to full cold and slowly warms up never to exceed the 1/4 indication on the arc.
So my questions are:
1. why does the indicator on the gauge stop 1/4 the way up the arc position and not what it used to (barely touching the bulb on the thermometer/half way)?
2. why does the gauge not return to full cold after the truck has cooled? (like it used to)
3. why does this 180 degree stant t stat only get to 160 degrees as verified with a laser temp gun?
What is going on here?
How can I post a picture?
Thanks so much for your help
