This site saves $$$! | Ford Explorer Forums
98BlackXSport
Vancouver, BC, Canada
'98 Sport OHV
I just wanted to say thanks to the moderators and everyone else on this site. I was experiencing the infamous "clunking" when braking and accelerating. Before I found out about the slip yoke problem from this site I took it to 2 shops. One told me it was going to be $1200 cdn for the diff to be repaired and the other told me that it was going to be $500 cdn for the transfer case to be repaired. This weekend I dropped the drive shaft, stuffed in a ****load of grease into the yoke and put it back in. NO MORE CLUNK and I still have money in the bank. Thnx again.
Glad to see the site has helped you save $.... don't get me wrong, but since joining this site, i have learned a lot automotively.... but i have started repairing and modifying my truck... the modifications are co$tly :)
i have a clunk when i stop suddenly at a light, but it doesnt do it when i slow down sluggishly, and doesnt do it when i take off, is this the slip yoke problem?
Could you put a link to that thered. I get a clunk also. Thanks
This site is great. The folks here know more about Explorers than most Ford Dealers do!
If you have a question Explorer related it's a 99.9% chance someone here can help you with it.
I had a clunk in my dash area when I would brake and accelerate. For a while I thought it was something inside the dash I couldn't reach. Then the other day i realized it was the cigarette lighter rolling back and forth in the ashtray :) :)
i can agree this site is awesome!!!!!!!! I also save a lot of money fixing my truck myself. Then again i think i have spent even more money because of this site! I see everyone's explorer and i want to do the same. I save money on repairs but i spend more on upgrades and mods. thanks everyone. its like having a new truck all over again when you do something new.
For those who do have this clunk, just search for "slip yoke" on this site. If you still aren't sure about how to go about fixing it, go buy a manual...it is a good investment. I can go through the procedure that I used on my 98 sport 4x4...
1. Pull truck into garage or level surface.
2. Block front tires.
3. Put truck in Neutral with e-brake ON.
4. Jack back end up to get wheels off ground and support with jack stands or what have you.
5. Use some paint, I used touch up paint, to mark the orientation of the drive shaft flange and the diff flange, do the same for the transfer case.
6. With a 12pt 12mm socket, remove the 4 bolts on the rear of the drive shaft. You might have to release the e-brake to turn the shaft to get at some bolts. Then put it back on so the shaft doesn't turn while you are removing the bolt.
7. You can then do the same for the front of the rear drive shaft. I didn't actually do this because the bolts on the front were really on there. Instead, I cut the one time use metal straps that hold on the rubber boot which is around the yoke. I then dropped the rear of the shaft and pulled the yoke apart. I looked inside the cup piece and saw shiny metal at the end, I then knew that was definately the reason for the clunk.
8. Take shaft to a bench and wipe yoke if grease looks dirty.
9. Clean inside of yoke cup and rubber boot if dirty. I just stuffed a rag in.
10. Load cup and rubber boot with a "****load" of grease. I used some high temp bearing grease, but any thick grease will work. I suggest using gloves. I went through 3 pairs.
11. Load male end of yoke with grease in grooves and on the end.
12. Stuff yoke together to push grease to the end. i had to push hard to get the air out because the grease acted as a seal.
13. Pull yoke apart again and repeat 10,11, and 12 to your disgression. Don't forget the rubber boot.
14. Orient your paint marks on the flanges. May have to turn shaft.
15. Put the 4 bolts back in.
16. Install some new hose clamps on to boot. I used a 2" and a 2.5". I think a 1.5" and a 2" would have been better so you don't have much strap left over. Stainless is a ***** to cut.
17. Clean up any excess grease.
18. Lower truck and take for a spin, NO MORE CLUNK!!!
Hope this helps.
yes you have to love this sight for every thing
