throttle bodies & MAS | Ford Explorer Forums
Limited Ex
Elite Lurker
Greensboro, North Carolina
94 Limited
The next engine upgrade I would like to do is put in a new throttle body and MAS. Just curious, what kind does everybody have, how much was it and what brand would you suggest? I am debating between this and getting a new set of headers, and if I can get headers less than what a new TB and MAS would cost, then it will probably be the headers.
I saw in your sig that you have an exhaust upgrade. Do you also have a filter upgrade? If not, you should do that first (KKM or KN). Besides that, my suggestion is the BBK 66mm TB. A larger MAS probably wont give you much on a mildly modded motor, and headers will cost you low end torque, which you probably want since I see you have large tires.
Maybe instead you should get a chip. Yes, the BBK TB and a chip.
i find that on the 4.0 that a new Tb and bigger mass air compliment each other very well and you will see bigger gains with them then you think. i prefer the bbk TB and the pro-m mass airs.
I already have a Superchip and a KKM, and I've been leaning towards a new TB and MAS, but just want to make sure I get the most bang for my buck!:rolleyes:
How much did your Pro M cost and where did you get it?
