Forder
- February 3, 2002
- West Point, NY
- '94 XLT, '05 Altima 3.5
I've had issues with the throttle sticking a little the past month or two. It would occasionally stick upon startup at around 2-2.5 grand (RPM) in Park and had to hit the pedal or restart it to get it to idle normal. I thought it was the TB butterfly valve so I sprayed a little TB cleaner (not carb cleaner) in there a few weeks ago and tried to scrub it out with a toothbrush and wipe it out. It seemed to help since it didn't stick anymore for a couple weeks (although it would only stick maybe once or twice a week before that anyways). Anyways, today I'm coming back from work and it started to stick a little coming out of the parking lot, I couldn't stop where I was so I had to just hope it unstuck while I was on the highway or something, hah. Then I hit construction work and had to slow/stop on the highway, so I put it in Neutral (to keep the truck from brake torquing) and stomp the pedal to un-stick it... very bad. Now it's stuck at 4k in Neutral and almost 2k in Drive, I had to hold the brake with the RPMs at 2k for almost a mile, I seriously thought my tranny was going to fall out, lol. I stopped right as soon as I got off at a gas station to play with it and after several attempts of playing with the throttle cable it wouldn't un-stick. So I pull off the intake hose to the TB to see if it's stuck and it's not, it's fully closed, so I start it to see if it stays closed (not a good thing to do, I know), it does and idles somewhat normally (albeit a little rough since the MAF was bypassed) around 600. So I hook up the intake again while it's still running and it instantly surges back to 4k. I pull the MAF cable and it goes back down again (rough/sputtering now though, hah). I tried to drive it for a second without the MAF hooked up and it just surges again when I put it in Drive and sounds like crap, so I hooked it back up and drove it home like it was. I was literally doing 55 MPH without touching the gas pedal. I know my tranny was hurting when I got back in town and home with all the stopping/slowing, hah. I won't have time to play with it until the weekend, but after searching for MAF posts, none of them mention high idling. But since the butterfly valve was fully closed (I saw it), how is it the TB? Any insight is greatly appreciated. Thanks in advance..
