Tick noise when I brake | Ford Explorer Forums
Mrobs146
Westland, Michigan
2003 xls 4x4
I just put new calipers, rotors, and pads on my 03 bled the brakes. Now when I go to stop it’s making little tick noise when I release brake it stops. Need help!!
not familiar with the 03 but is there a shim kit that you didnt install? Also tray spraying back of pads with a brake noise spray
It could be so many things. But it’s only brakes right?
Take it back apart and check everything.
It sounds like the brakes I do t know what else would make that sound when it only happens when I apply the brakes
Guess it’s because they’re slotted and drilled rotors
