Spokanedad
- March 31, 2010
- Spokane, WA
- 2000 Limited 4.0 SOHC 4WD
Hey all-
I have a rhythmic thumping that is most evident at slow speeds and smooths out a bit as I get up to cruising speed. All front end and harsh.
Info:
1. 92 4.0 OHV with 2' lift kit, w/ 31's.
2. Replaced both front races and wheel bearings yesterday.
3. New front brake pads, rotor is in good shape and not warped. Brakes bleed and flushed with all new fluid.
Issue:
1. A lot of slop remains after changing out front bearings at 9-3. I was disappointed it wasn't the bearings, although I bought this truck two months ago and one bearing set was dry and rusty, so it was good I did them.
2. The grease boots on the tie rod ends won't hold grease anymore and although they don't move I know they have to be bad.
3. I have no idea how long the ball joints have been in their and the aren't the greasable type.
What is the likely cause of the thumping? I will eventually replace all of these parts but I want to get rid of the horrific noise first and move on to the other PM work as I can afford it.
Thoughts?
Thanks!
Jeff
Info:
Issue:
Thoughts?
Thanks!
Jeff
