tip of the day on brakes | Ford Explorer Forums
mcgyver ky
ky where all the mud is
91ford exporer eddiebauer
got a busted brake line heres a idea allways keep some reinforced fuel line with you and some hose clamps just clamp the hose in the gap of the two lines it will get you home
one more tip on bleeding the brake line when your by yourself things you need are a hose that will fit on the end of your bleeder and a can or bottle fill the bottle 1/4 way full incert the hose in bottle till hose is below the fluid level ,open bleeder and press brake to floor as many times as needed till no more bubbles come out line tighten bleeder remove hose your done
note make sure you keep brake fluid in bowl to the right level or you will be bleeding all the brakes
