torsion twist | Ford Explorer Forums
torsion twist
squirrelu
southington ct.
1997xlt 4.0 sohc 4wd
need some help on my tt bolts I did the tt and come up to 1.25 the bolt on the drivers side & the passenger side are not long enough to do the 2" tt I picked up new bolts to go in. what I need to know is can I just take the bolts out or do I need a special tool to do this. I know that u need the tool to do the torsion bar.
ok im sure that you read through all the tt post so and i know theres one some where that covers its but all you need to do is get all your mesurement down and the use jack stands to hold the x and then remove the old ones and put the new ones in now dont just crank on them start of with the hight you had with the old ones drive aroud abit to let them set and then go from there intill you get the lift and i would stay just under 2'' thats how i did mine and it came out great and with staying just under 2'' i know that the cvs are not basicllay maxed out just sitting in the drive or just driving around on the black top
