Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
It was not a fun day when driving to work one morning this week. I heard a loud bang and within a mile or so the car started making a horrible grinding noise. First I thought that one of the driveshafts came loose since I was working on them recently, but I crawled under the car and shook everything and they were solid. The car was not drivable, so I called AAA and got towed home. While waiting I checked all the wheels and noticed the passenger rear wheel has some play when I pushed the whole car. That gave me an idea that something gave back there. Took the wheel off at home and sure enough the rear wheel bearing was completely shot. The wheel was dancing around and was held just by the axle, the hub was on its way out of the bearing. I have few theories since I had this bearing pressed in maybe a month ago and I used a Timken. The nut was loose but now I wonder if the failed bearing made it loose or the loose nut caused the bearing to fail. Called few salvage yards around and got the whole knuckle assembly for $ 100 in Newark. Since they did not want to waste too much time taking it apart, they just gave me the whole thing with the brakes, caliper and the CV axle. The swap took maybe an hour, I bought new axle nut from Ford and installed it, and also used the old one on top of the new one as a locking nut, there is enough CV sticking out. I did the same thing on the other side as a precaution.
My advice, whenever you do any axle work, especially in the rear, get a new nut, or use thread locker.
Failed bearing
"New" assembly
Failed bearing
"New" assembly
