So other than showing off or getting unstuck any other reasons for the button? Okay so I got high centered a few weeks ago and I first switched to 4x4 high, no luck, and then I tried it with the traction control off still no luck, finally I went to 4x4 low, and gave up. If the traction control doesn't help as much as I thought it did, other than paying for tow service, what am I supposed to do?
ANY IDEAS I NEED HELP!!!
I am leaving for pismo beach on the 16th or 17th what do i need to drive in sand????
Well, if you were high centered then all the traction control in the world won't help if you don't have any rubber on the road with traction for it to control
To drive in the sand:
Air down the tires before you go out on the beach. Make sure you have a tire pressure guage with you to check the tires when you air them down (and later back up). I suggest 20 psi at least, some go as low as 17psi, 20 is usually plenty fine for me.
While driving in wide flat areas where you can go faster, I would use 4 high with traction control on. If you want to hot dog, turn off the traction control.
If your in steep, deep, curvy, or other types of areas, use 4 low. The traction control will automatically turn off for you and turn back on when you exit 4 low.
Bring a folding car snow shovel with you to dig the thing out if you get stuck or high centered. Someof your serious folks bring a jack and boards to jack it out. Unless your in a really big bog or something crazy you shouldn't get that stuck. Careful going over the tops of dunes, you'll get high centered here.
Don't drive through the salt water like the commercials, hit a pressure car wash when your done to get the salt off.
Drive it like you stole it, just don't roll it
Finally, take a picture on the beach like this
