elliottut
- January 2, 2002
- Seattle, WA
- '92 XLT
I just had my 92 manual tranny towed to the shop, but they won't be able to look at it til monday. The truck has 142K miles, a 5speed manual, and has recently (for the first time) towing a trailer with loads of 2 yards of gravel about 7 miles at a time.
Here's what happened and I need opinions as to what people think might be wrong and how much $$$ I'm looking at from a good local shop:
Yesterday I was driving around shopping, and while waiting to pull into a parking space (clutch in, in 1st gear) I hear this pinging sound (like metal popcorn and springs bouncing around in my transmission area). I decide to leave the shopping and drive it back to work. I have to work hard to get it out of gear and get it into gear, and then the noises go away and everything seems alright. I drive it back to work.
That evening I start to drive home. As I get off the highway and onto the exit, it seems locked in 5th gear. I finally yank it out of 5th and once again start hearing pinging popcorn from the tranny area. I decide to pull into the nearest parking lot. I barely make it into 1st and 2nd gear to get the thing through stoplights and into the parking lot. There are some really nasty rattles and lurches of the vehicle . I get it parked and shut down.
Out of desperation, I add some more fluid to the clutch fluid reservoir after seeing that it is almost totally empty. Doing this, I see that the fluid looks almost grey (not normal, but does this have anything to do with a bad clutch?) Of course adding fluid had absolutely no effect. I could not get it into any forward gear at alland reverse would only grind when I tried to get it into gear. Being in neutral, there is no noise.
So what do you think: a clutch that finally disintegrated, or a tranny that needs rebuilt? The guy at the shop said if it's a tranny (worst case), it would be $2-3K (I would have to junk the car if that is the case, it has been driven fairly hard).
I know this is long, but I need some good educated opinions on what might be wrong, what to look out for by way of a mechanics explanation, and best case/worst case scenarios (need to start shopping for a new Explorer?)
Thanks for your help.
Desperate.
Desperate.
