IloveGod
- May 31, 2018
- Saint louis, MO
- 2006 , mountaineer luxury
Hey Ford family,
I recently bought my 06 mountaineer 4x4 about 3months ago. I was told it was having tranny issues and it may be due to low fluid, I should’ve asked more questions about the issue but you live and you learn.
The issues I’m having are: slow acceleration from stand still, high rpm in D gear + OD doesn’t work, I have to drive in 3rd to go over 20mph as if it was my D gear, and no power in reverse
I’ve had the check engine light scanned and it gave back the following codes: p0743, P0455,P0457,P0750,P0760,P0765.
I figured I needed to replace the solenoid pack, but when I checked under the hood the bulkhead connector was totally unhooked. Transmission shop stripped my t30 when trying to check the fluid {never told me they stripped it just said it was stuck
} so I dropped the pan and there’s no unnormal debri in the pan.
My question is since the bulkhead connector was disconnected are those codes reflecting back to the solenoid unreliable? If so what may be my problem. Really trying to avoid a complete rebuild.
Ps, car drives great when it’s not coming from a complete stop or in reverse .
Thank you for reading,
