Tranny Question | Ford Explorer Forums
Tranny Question
dud_05
Richland Center, Wisconsin
'95 Explorer EB
I have a '95 EB and sometimes when I am accelterating the tranny will slip a little just just be for it shifts in to drive or overdrive. About the time you think it should be shifting the motor will go up almost 500rpm or so then it will shift. It has 123,000 miles on it. I was just woundering what I should do, or if its too late cuz it's already slipping.
Your problem is likely in the valve body, which can be removed and rebuilt, have the solenoids checked, or just replaced with a rebuilt one. Could also involve the OD servo, which CAN 9with great difficulty) be repalced without removing the trannie as well. My guess is VB.
