Lefy
- December 13, 2002
- Westchester, NY
- 98 Sport 4x4 4.0 SOHC
I just finished rebuilding the the valve body last week drove well
Put fresh fluid in it drove it till Saturday Then flushed the pan again and put new fluid in again as the fluid was pretty dark. I put cheaper fluid in (castro merconV) because I was going to flush it again once I got to Syracuse.
I was some what in a hurry and put a little to much fluid in.
left home yesterday to drive to Syracuse and it was shifting well and seemed to be driving fine highway speeds 65-70mph.. There were two of us in the truck with all our stuff for school. The truck was packed. even had my tools and winch in it.
About 200 miles into the drive The Overdrive light starts flashing and I back off her and turn over drive off. slow to about 50-55 trying to make it to the
rest stop 10 miles further. about 2miles later.
I feel a difference in the throttle and look the rear view and see white out smoke.. I instantly turn on the 4ways and put her in neutral and turn the engine off. coasting on to the shoulder.
Trans is puking fluid and I can't really make out where it's coming from. as its every where. I think its coming from the bell housing as its dripping there but the tow truck driver says it looks like the cooler lines. right at the trans.
get towed to school for free 65miles Thank you AAA.
I have it in the garage and I'm going to wipe it down as much as possible and then put a quart in and see where it drips from.
I think it may be the front shaft seal but I don't know.
Is that something that would be difficult to replace?
I know dropping the trans and removing the exhaust and tcase is going to be fun but Is it that difficult to replace that front shaft seal?
That what I read goes on the a4ld transmissions.
Could having too much fluid in the trans cause the seal to go?
Thanks for any help
Thanks for any help
