trans help no OD | Ford Explorer Forums
trans help no OD
fishin
Utah
92 explorer
Hello and hope samone can help. I had my trans rebuilt 5000 miles ago and now i have not overdrive.It work good in 1 2 D but OD is no longer working .If im going down the freeway it semse to work but if I step on the Gas it slips. It does not work at all if im at a light and try to start off in OVer drive. Is it ok to drive it with out OD working im getting Married nest mouth and need it to go to Idaho for are hunnymoon an uprizing a SCA event thats for your help
Won't the rebuilder stand behind it ?
Welcome to this forum! Do you have any codes coming up? Sometimes there could be another problem like the TPS, brake on, and off switch (BOO), or the VSS that is the culprit. The band could be out of adjustment, or the solenoid could be defective. In some cases the internal wiring harness could have a bad connection, a short, or melted insulation that could be shorting to the case, or to the other wires. There are 3 wires in that harness. One is a constant positive, and the other 2 are for the TCC, and 3-4 (OD) shift solenoid.
In another thread, there was a case that somebody had crazy shift points. They had a transfer case that wasn't behaving properly. It turned out that the front, and rear tires were a different size. The vehicle's computer thought that the front wheels were going 30 MPH, and the rear wheels were going 50 MPH.
