RickMar
- April 11, 2009
- N. Andover Massachusetts
- 99 Mercury Mountaineer
Hello,
Thank you for taking the tine to read this message.
I have a 1999 Mercury Mountaineer 5.0L AWD.
I have been having a problem trying to figure out some chattering vibration I experience when my wheels are turned and I back up or pull forward.
I had a post out hear on April 11,2009 and got some good advice.
Friday I took the Mountaineer to a very reputable mechanic to get his opinion of where the problem lies. I was told it could possibly be the transfer case.
If I drop the front drive shaft (and the chattering/vibration goes away) …the viscous coupling inside the t-case is likely going bad.
In that case I know without a doubt the transfer case is bad and I continue to drive the vehicle with the front drive shaft disconnected and then only have rear wheel drive… would I be driving a time bomb ?
I have seen the “Sticky” about it drifting in park. To prevent this I will always use my emergency brake to keep it stable.
Any information will be very much appreciated.
Thank you,
Rick
Thank you,
Rick
