bigfld63
- May 28, 2010
- Texas
So the "Check Transmission" popped up in the message center the other day along with the infamous flashing O/D light. After extensive reading on this problem I broke down and took it to dealer to at least get the diagnostics. Here is my problem:
2005 4.0L 4x4 with 110,000 miles last change AT fluid at 95,000 (No it is not low). Doesn't drive poorly, shifts just fine, warnings only go off after a few minutes at highway speed.
Dealer says there is a valve stuck in the valve body and looks like the solenoid pack is on its way out. They priced both repairs at around $1800. Clearly, I am not getting repaired at dealer. But I would like to know if you all think the diagnosis is appropriate? Could I start with solenoids first and hope for the best or what should my next step be?
Thanks!
Thanks!
