Transmission Problems and OBDII Codes | Ford Explorer Forums
Daisywheels
1999 XLT XP SOHC V6
I just finished a motor swap and managed to get rid of all my OBDII codes coming from motor. However, Transmission is not so easy. MY possible answers are in ALL CAPS. Does anybody agree?
Trouble Code Report on 5R55E Ford Explorer Tranny
NOT SHOWING HERE IS FLASHING O/D LIGHT
AND I AM STUCK IN 4X4 HIGH
CAN FIX BY TAKING SHIFT MOTOR OFF AND MOVING SHAFT TO “N” ?
P0118 PowerTrain - Stored Engine Coolant Temperature Circuit High
SEEMS MINOR – WILL CHECK AT THERMOSTAT HOUSING ?
P0743 PowerTrain - Stored Torque Converter Clutch Circuit Electrical
COULD BE LOOSE OR BAD CONNECTION SOMEWHERE?
P0760 PowerTrain - Stored Shift Solenoid "C"
P0715 PowerTrain - Pending - Input/Turbine Speed Sensor "A" Circuit
I really don't know I am guessing.
Help? Thanks -DW
