ParkerRocker
- March 9, 2008
- Hayden, ID
- 92 Explorer Sport
I'm embarassed to ask this question because it involves revealing to you that I have been known to (on occasion) stall my car out almost immediately after starting it and trying to go somewhere. The problem is when i try to start it the second time. The starter just pulses but no engine turnover, thus no engine start. it will stay like this for about 5-10 minutes then when i try to start again it works fine. I have been told that pumping the gas would have no remedy on this vehicle, but I swear that it helps, all I have to do is release the pressure on the ignition while pressing on the gas at the same moment. it's tricky to time ti right but it can be done. (Maybe i'm on crazk and it's really not helping, that could be a possibility.)
My question is: What is causing this? is it a bad starter? and if so, where exactly is that located?
