FFATS357
- March 18, 2009
- Ledyard, Connecticut
- '96 eddie bauer 4.0L 4wd
Ok im beyond my knowledge now, im new to posting so I apologize in advance if im in the wrong area or writing to much, but I've been saved on other repairs by reading other peoples posts and know if anyone can help its you guys. First you should know its a '96 eddie bauer 4.0L 4wd. I was troubleshooting a starting problem and had power to everything. The enginge would crank (slowly) but not start, so I removed the starter and had it tested. It was good so I reinstalled it. while I had the battery disconnected I went ahead and replaced the solenoid(relay) thinking that could be it. I attached the battery and went to start it but had no power at the ignition or anything else inside the truck(didnt hear any relays clicking or fuel pump either). I began checking all the conections I removed, they were all tight. Using a multimeter I checked the battery for power which it had and the solenoid terminals which were also good. I was getting power down at my starter cables and good grounds everywhere. So I reinstalled the old solenoid because I had power with it before, still no luck. I could jump the solenoid with a jumper and get the engine to crank but still no power at the distribution box or fuse panel to the accessories. I checked all the fuses in both with a continuity tester but all checked back fine(the fuses,still no power to them though). Now im stuck with no idea where to turn next. I'd like to check my fuel system and spark plugs but cant untill power is restored. I've changed starters and performed other repairs on other vehicals before but never experienced this. This is my first explorer and im trying to keep faith in them but im feeling the pressure on this fix. Please help. Any suggestions would be appreciated. Thank you.
