mall
- December 21, 2010
- Illinois
- 2003 xlt
Troubleshooting the 5r55 transmission for dummies
I will continue to clean this up and simplify it. Feel free to add to this and if you are a moderator edit it as necessary if you are so inclined.
click on this link to get links that work
1) check the fluid...there is no dip stick, here are the instructions.
(dead links)
2) check the codes...this link will help determine what the codes mean. hopefully I can get some help with what the
transmission codes mean in laymen's terms
3) check the fluid pressure...this thread will help with the procedure. again I would like help explaining what incorrect pressures indicate in terms of parts replacement
4) change the fluid...this thread will help you change the fluid
5) check the servos...this will help you understand servos
6) check the solenoids...here is the process to check the solenoids.
7) replacing solenoids
8) tighten the bands...this will help you properly tighten the bands
(dead links)
