_91wagonguy_
- February 26, 2021
- CT
- 1999 Ford Explore Limited
Hey
, I have a 1999 Ford Explorer Limited 5.0L AWD.
When I use the right (passenger) side turn signal It causes all (3) of my rear stop lights to flash with the Amber turn signal. I've unplugged the connecters for the rear bottom stoplights on both sides to test and for some reason the turn signal power is being sent to the all the stoplights through the (green wire) and not sure if its a short or the multifunction switch.
This malfunction only happens when I use the right turn signal and I've checked the trailer wiring and its fine.
Thanks.
Thanks.
