PrinceAli
- October 15, 2015
- Kitimat
- 2007 Ford Sports Trac V8
Hi,
If there is anyone out there that can help me out with diagnosing the problems.
1. Recently as I am driving (mostly noticed going uphill, but also sometimes straight) that around 1700RPM, 60-100km/hr the trucks does slight jerks, its small but noticeable as if it may stall. It usually stops when i rev up to a lower gear but it does a few hops. I was thinking maybe it could be a misfire?
2. My driver side when i start the car cold, or after a few hours it stars to make a leaky sound, its very in sync with the engine rotating and makes a loud ch ch ch ch sound. It turns out there was a lose bolt/stud on the driver side that snapped off.. my question is what do i need to do to replace it all, i was thinking all studs, manifold gasket? and anything else?
Also i tried looking around the web for a repair manual for the 2007 Ford Sports trac 4.6L V8 to download/buy, does anyone know where to find one? i have had no luck and not sure what real/etc?
Thanks in advance!
Thanks in advance!
