uh oh.. went muddin.. now a steering problem
BoatsRcool
Greenville SC (Home) Clemson SC (School)
GMC Yukon 4x4
i just went through a couple of holes today, but um now when i brake, especially hard, the steering turns it self to the left REALLY bad, i mean i can control it fine as long as i have both hands on the wheel.. what could it be! other than that its driving fine.
I suggest you inspect your brakes and steering for mud that might be fouling things up.
Definitely check the brakes. Sounds like the left front is grabbing/locking up. Pull the calipers off and clean everything up real good. See if that fixes the problem.
ill do that,thanks
well i took off the left wheel. and the disk looked clean. i cant figure out whats going on!
Did you check the front and back sides of it? Did you take the caliper off to see if any dirt was in between the pads and rotor?
no, but i will tomorrow, i have never taken apart the brakes, so ill have to check it out in the daylight.
i dont understand how a little dirt could do this though
Could just as well be the right side not working.
Take it to the car wash and blow all the crudmud off & out of the brakes and they might work. If not it will be cleaner when you remove them.
You should clean the pins that the caliper slides on. You know the ones you take out when you change that pads.
see i have never worked on brakes haha
Top Bottom
