tankhokie
- February 11, 2004
- VA
- '96 E.B. 5.0
ok, quick summary.
'96 X 302 with a hesitation/miss/stumble at low rpm and slight load on engine like a small incline.
i pulled out all my autolite plat plugs (fairly new) before a long trip this past weekend and found this:
bank 1 (passenger side cylinders)
all 4 plugs looked great with slight wear, still gaped fine 0.052-0.054
bank 2 (driver side cylinders)
all 4 plugs showed MUCH more wear, gaps were opened to around 0.062, the inulators seemed to have a worn (maybe hot?) spot on each plug (looked like a single round worn spot on the insulator) also a small amount of chaulk like deposits on a few of these plugs' electrodes.
so i cleaned and re-gapped. during our trip we noticed the problem (miss) went away. i couldn't make the miss come back. BUT then after a couple hundred miles, the miss is coming back, less, but still coming back.
SO...what do you guys think could cause the one bank of cylinders to cause advanced wear, strange deposits, etc. but not he other bank???
i know the coil packs are not divided by bank sides, but the O2 sensors are...i am getting no codes set, but wonder what can cause this condition??
thanks again
thanks again
