Westsign
- July 15, 2016
- Monroeville,pa
- 03 Sports Trac
Hi,
I was thinking of replacing upper ball joint on Drivers side in the front.
Can you replace just the ball joint or do you have to replace UCA with ball joint already pressed on.
I'm a little concerned about replacing the UCA and getting lined up correctly to avoid a front wheel alignment.
Any help or suggestions would be appreciated.
Thanks,
westsign
Thanks,
westsign
