ashleyroachclip
- February 24, 2004
- Roseburg Oregon
- 1991 Explorer EB
wifes 91 ex. was running really poorly, found it was low on coolant , and the cruise vacumn line had come off.
Reconnected it , filled the coolant level up , ran codes.
What I came up with is , upstream o2 sensor lean ,,51.00 for a new one ...
the truck runs good after it warms up . when you try to start it in the morning, you have to crank till it starts , a sec or so , then it dies , then the same , a sec or so , on the 3rd try it starts and runs but rund rough , as it warms up it smooths out .
Once the truck is warm , it runs fine , not as well as my ranger w/4.0 but pretty well .
I can't stand to listen to her complainn as to how well my truck runs and how hers does not . any help would be great , and I'm figuring up stream , means before the cat ?
