vac line came loose, can't find where it goes..2002 | Ford Explorer Forums
dablack
Houston
2002 XLT
I was replacing the plugs on the PS and when I looked around to clean up I saw that one of the vac lines was hanging loose. I have no idea where this bad boy goes.
Let me explain which one it is. There are two vac lines coming out of the firewall on the PS right beside the PCM wires. One of the two vac lines goes to the intake and the lines turns red near the intake. The othre vac line (my loose one) has a 90 degree bend in it and then another connector. This is the part I can hold in my hand and I don't know where it goes.
thanks
Austin
Never mind. I finally found out. It went to the controller on the hot water line.
thanks
Austin
