Kamel
- October 9, 2008
- Orange Park, FL
- '95 Ford Ranger XLT 2.3L
If you'd like to see a very quick version of this post scroll to the bottom to the "Just a quick recap:" part.
I have personally never seen this before and have no clue what to make of it.
Best I can tell, the trailer itself is working fine with all the wiring etc. but perhaps I'm wrong. I'd love to put it on a different truck to verify but unfortunately I can't find one and I'm pressed for time.
I borrowed a trailer from a friend to make a 250mi trip. The left tail light was out on it, but only the running light (mind you this is the first time I have used the light connection on the truck since I've had it). Looking at the encasement, the side red translucent plastic part was missing and the light looked like it had some relatively mild water damage/rust. I replaced the lamp and the problem was not fixed.
After returning and testing, I discovered the tail light functions perfectly fine when connected without the running lights on. When the running lights/parking lights are on, however, the left brake light does not work at all, not the running light and it will not light up when the brake is applied.
After some fiddling around, I discovered that there are 3 electrical plugs in the compartment with the jack. When I remove the last one, it seems to disable the running light functionality. I am afraid that it still may not be enough to keep from getting pulled over though.
Any thoughts on the problem? I am very electronically inclined, so I should be able to troubleshoot and fix this somehow. I am guessing a relay or fuse is out but I have no idea.
I did, however, check for a good connection with a multimeter between each of the 4 wires connecting the trailer to the truck and all 4 wires have a good connection.
Is there a way I can test the trailer connection using a multimeter? Is this just a simple fuse? Any suggestions would be MOST helpful as I should be leaving here in about 10 hours and my wife and I are moving out of despiration hoping for better luck getting jobs in KY where my family is from. We really can not afford a ticket right now
Just a quick recap:
*First time using trailer connection on vehicle
*Vehicle did include tow package from the factory and the components should all be factory original.
*Trailer had a bulb blown but replaced both bulbs in encasement
*When running lights are on, the running light does not work nor does the brake light work, the left tail light essentially does not work at all.
*When the lights of the truck are not on, the tail light functions fully as intended
*There is a missing red plastic piece on the side of the tail light which has probably let some water in causing the bulb to blow. The trailer (including encasement) was dry when I got the trailer however. I have also since gotten tape to seal the tail light back up once I fix the problem.
Just a quick recap:
