TheExplorerGirl
- May 10, 2015
- Richmond, VA
- 1999 Ford Explorer
Hi...I have a 1999 Explorer XLT 4×4 with the 4.0 Sohc motor. I'm trying hard to figure out what could possibly be causing a hard clanking under my feet and a vibration when accelerating and sometimes at higher speeds. Well, it's more noticeable then. It's constant though, just doesn't feel as bad. The clanking happens when I hit bumps or even just roads with uneven spots. Here's what's been recently replaced or done in The past year: Motor swap, New tires, wheel balance,front upper control arms and ball joints, front lower ball joints, shocks, alternator, oil pan gasket, and an Inspection done this month. Will need rear brake pads and rear sway bar links soon, according to the inspector. I've been told my issue could possibly be a U joint. I'm not sure what to look for or listen for to see if that is in fact, my issue. Could I ask you all for some help?
